Author Topic: Image Calibration Error Message  (Read 2160 times)
Offline Mariner10
« on: 2017 July 13 22:15:31 »
Hi people,
Can I ask for some advice please?
I’ve just started the processing process on a second image after completing my first one.
I'm right at the start of the process doing image integration.
As I'm a little slack I'm using the same calibration files (darks, bias and flats) as I did on the first image (without any issues) and I got the following error message on the second image:
ImageCalibration: Global context
Loading master calibration frames:
Loading calibration frame image:
C:/Users/User/Pictures/QHY8L/Master Calibration Files/superbias.fit
Reading FITS image: 32-bit floating point, 1 channel(s), 3328x2030 pixels: done
Normalizing sample values: done
40 FITS keywords extracted
C:/Users/User/Pictures/QHY8L/Master Calibration Files/Master Dark.fit
29 FITS keywords extracted
C:/Users/User/Pictures/QHY8L/Master Calibration Files/Master Flat.fit
35 FITS keywords extracted
Applying bias correction: master dark frame ...
Dark frame optimization thresholds:
Td0 = 0.00000000 (189 px = 0.003%)
*** Warning: The dark frame optimization threshold is probably too high (channel 0).
Computing master flat scaling factors ...
*** Error: Zero or insignificant scaling factor for flat frame channel# 0. (empty master flat frame image?)
<* failed*>
As I used the files on the first image with no issue I’m perplexed as to why I would be getting an error message now.
I tried doing another calibration of a flat file and using that instead of my original one and that too came up with the same error message.
Cheers.
Steve West
