Author Topic: Unknown Error on StarAlignment w/Drizzel'd files v1.8.5  (Read 2167 times)
Offline rjbokleman
    • Astrobin
I'm attempting to use StarAlignment on LRGB frames that have been Drizzel'd using 1.8.5 on Windows 10.  Never had issues before, but I've got a GREEN frame that simply tosses an error in PI when running the StarAlignment:
*** Error:
*** Error:  Unknown Exception
*  Applying error policy:  Continue on error.
Is all I get.  I've tried this on macOS w/1.8.5 as well same issue.  Is there a way to debug this perhaps?  In the meantime, I'm going to try and back up a few steps and reproduce the GREEN channel Drizzle files.
Thanks!
Offline rjbokleman
    • Astrobin
Re: Unknown Error on StarAlignment w/Drizzel'd files v1.8.5
« Reply #1 on: 2017 August 11 16:58:07 »
On macOS it fails if I use the GREEN channel as the reference image similar to how it fails if I use the L channel as the reference image.
StarAlignment: Global context
Loading reference image:
/Users/rjbokleman/Library/Mobile Documents/com~apple~CloudDocs/PixInsight/NGC 6946/NGC6946_Fireworks_Galaxy_NGC6939_Green_Drizzel_Additive.xisf
Loading image: w=9312 h=7040 n=1 Gray Float32
Structure map: done
Detecting stars:   0%
*** Error: Unknown exception
<* failed *>
On Windows 10 w/GREEN channel as the reference image, it causes PI to have an unhandled memory exception.  At the end of the day, I was able to first crop the Drizzeled images and then got StarAlignment to run against them.
First time experiencing this kind of thing.  It's not relevant to 1.8.5 either as this same issue with this dataset happened on an earlier 1.8.4 version as well.
« Reply #2 on: 2017 August 13 03:05:23 »
This is a weird problem that I cannot reproduce. To understand and solve it, I need the images that are causing it. Can you upload them? Thanks in advance, and sorry for  the trouble.
Offline rjbokleman
    • Astrobin
« Reply #3 on: 2017 August 16 05:29:32 »
Juan,
Sure, be glad to.  The forum won't take the files over 512k, these are 256MB each one for each channel.  Is there a special place to upload them?
