Author Topic: BPP Integration  (Read 2362 times)
Offline Rob_x
BPP Integration
« on: 2017 March 16 06:43:17 »
I am currently using BPP to process my images. Although it is not recommended to use BPP to integrate I wanted to see what BPP does in contrast to what I do using ImageIntegration .
After  BPP has processed all my flats, lights, darks and bias frames, it generates an integrated images. For a split second I can see three windows at the end of that process until they are closed (Pixinsight is still running). The integrated image is not saved either so I have no way to see what BPP actually generated.
Do I have to set a flag somewhere or is this a bug ?
Rob
Offline TobiasLindemann
    • Trackingstation
Re: BPP Integration
« Reply #1 on: 2017 March 16 13:23:50 »
Hi Bob,
you have to select a output directory where your files have to be saved. Here you find a masters folder where our integrated image(s) are saved.
Tobias
Offline Rob_x
Re: BPP Integration
« Reply #2 on: 2017 March 16 14:21:05 »
Thanks Tobias, that did the trick :)
Somehow I was under the impression that the windows stay open after the final step
