Author Topic: xsif format in batch preprocessing  (Read 2657 times)
Offline sctall
  • scott
« on: 2016 August 01 18:47:18 »
Its been awhile since I used PI for DSO. I just updated everything, and when I went to use BatchPreprocessing, to calibrate, Dark, Bias, Flat and Light frames. In the diagnostics I got an error message saying no files to support xsif format.
I have all files in the .fit format, from my Starlight SXVR.
I had to use the .fit format, which is what I want to use anyway.
I really don't see how you think the .fit format should be deprecated. It is the most common format in astrophotography there is.
I just have to convert the .xsif anyhow.
But, if that is what I need to use here, What's up with the error message?
--scott--
ES102, WO GT81, astronomics, guide scope  CEM60
ASI120MC, ASI224MC, ASI178MM
Lunt60 SS,  moonlight focuser
LX200GPS
Re: xsif format in batch preprocessing
« Reply #1 on: 2016 August 01 19:39:25 »
i'm guessing that PI has lost track of the library file that contains the xisf support. you may need to do the pixinsight reset procedure (http://pixinsight.com.ar/en/docs/75/pixinsight-reset-pixinsight.html) but i think this will reset your customizations (if any) as well.
« Reply #2 on: 2016 August 02 02:39:17 »
The FITS format has been deprecated in PixInsight. Its use is strongly discouraged, except to import data generated by other applications.
To solve your issue, see FAQ 3.9: http://pixinsight.com/faq/
