Author Topic: StarAlignment error  (Read 2213 times)
Offline rweed
StarAlignment error
« on: 2016 July 20 13:35:57 »
I imaged two different galaxies on the same night and calibrated their images exactly the same way, but StarAlignment works for one but when I try it for the other I get the error message "unable to find an initial set of putative star pair matches". Does anyone have any ideas for why this might be the case? Thanks!
Offline MikeOates
Re: StarAlignment error
« Reply #1 on: 2016 July 21 06:47:06 »
Did you change the image to register with on the second galaxy image?
Offline rweed
« Reply #2 on: 2016 July 25 13:14:06 »
Yep I did. Could it be an issue with the number of stars in the image?
« Reply #3 on: 2016 July 25 21:02:41 »
these problems almost always boil down to star detection -
problem 1: the subs have very high noise, such as from an uncooled DSLR. the star detector is confused by the hot pixels and detects them as stars.
problem 2: the FL is really long and the stars present in the image are very soft (meaning they do not have strong peaks)
problem 3: the FL is really long and the tracking/guiding is bad, so the stars are soft and not particularly star-like.
the solution to 1 is to experiment with changing the noise scales and hot pixel compensation in the star detection tab of the StarAlignment process
the solution to 2 is to experiment with the peak sensitivity slider in the star detection tab of the SA process
sometimes problem 3 can not be solved and the only solution is to capture better subs. but #2 does sometimes apply.
a good way to figure out what's going on is to use SA in "detected stars" mode, which will generate an image which shows all the things that SA thinks are stars. you can then see if there are very few stars, or if there are a whole bunch of bogus stars.
