Author Topic: DSLR Bias-Frame Confusion  (Read 2292 times)
Offline aworonow
    • Faint Light Photography
« on: 2016 July 25 16:05:02 »
Folks,
Looking for some sage knowledge. I have just obtained a Canon 700Da cooled DSLR. That means I have adjustable ISO and Temperature. Looking on the internet, there seems to be no consensus as how best to treat these two parameters when shooting Bias Frames. For example, one site says use the temperature setting of the lights and the lowest ISO on the camera. Another says Temperature does not matter; another says use the ISO of the lights. etc.
Does anyone know the RIGHT answer? Thanks for pondering this esoterica. I appreciate.
Alex
Re: DSLR Bias-Frame Confusion
« Reply #1 on: 2016 July 25 21:15:06 »
always use the same ISO and temperature for the lights, darks and bias. the sensor gain is different at different ISO and you need the gain of the calibration frames to match the lights.
you might as well use the same temperature and ISO for the flats, but technically you don't need to use the same ISO. if for instance you are using a light source for your flats that has some native oscillation frequency, you may find that a high-ISO flat exposure would be so short as to not be evenly illuminated by the light source. in that case you can drop the ISO until the exposure is long enough.
this will complicate matters however as you'll need to do 2 runs in BPP: in the first, use bias and/or flat darks of the same ISO as the flats, in order to create a calibrated master flat. then you do a 2nd run of BPP with the light-matching ISO darks/bias/lights together with the pre-calibrated master flat.
Offline aworonow
« Reply #2 on: 2016 July 26 07:28:16 »
Rob,
  Thanks much. Clarifies everything.
Alex
