Hi Dean,
If you mask the brightest stars cores you can avoid it to happens. Other way could be to make Deconvolution in each channel. If you inspect the channels where the yellow is present, you will see that the blue channel has a darker area. See
this processing example with a similar case.
Saludos, Alejandro.
